temps on my Xp-90 with a Panaflo L1B fan
sidpaul
70
just put together an AMD 3000+ newcastle with a XP-90 and a panaflo L1B fan and some as5....temps are 44 idle with case temps 32 and load while running 3dmark loops go to 48.. shldnt my idle temps be lower???
Painman
3,728
29
86
It's probably a faulty reading... if you have good contact between the CPU and HSF then the CPU should typically idle 3-5º warmer than ambient case temp. See what the BIOS says.
Oh... what prog are you using to get this reading? If it's Everest, it might be mis-labeling things. Everest tries to tell me that my NF4 temp is actually my CPU temp, while my real CPU temp shows up under Aux. This is with DFI Ultra-D.
Texun
2,058
I have the exact numbers with my Newcastle 3800 and XP90. This is with Cool n Quiet disabled. When I enable it my temps drop to 29C at idle.
slash196
1,549
I'd say your temps are switched: your CPU temp is probably 32 and your case is probably 44. When you run Prime or SuperPI, look to see which temp has the greatest temp swing: that's your CPU temp. Just ignore the other ones.
