Temps for Cel D OCers
perdomot
1,390
Curious about what case/cpu temps my fellow Cel D OCers are getting. I've got my Cel D running at 180 X 20 for a 3.6Ghz OC. My vcore is at 1.475 and with a nice 92mm fan on the XP-90, I'm getting a reading of 44/29 for cpu/case. The current temp is 78 degrees around here in Miami. When it was cold a few days ago, mid 50's, I was getting an idle of 38/24 so obviously the climate is changing things a bit. How are you guys doing?
JohnAn2112
4,895
180 x 20? Do these Celeron D's have unlock multipliers? I may have to look into getting myself one.
superkdogg
640
No, they're not unlocked. Mine is 200x18 for 3.6. With the stock Northwood cooler on it, I have 60C under load and around 40C idle in a very cool (60F or so) room. Case has pretty good cooling as well. I think I'll run prime again-not to check stability but to warm up!
