Hello,
soon i will be looking to over clock my rig which will be soon, i will be looking to hit about 2.6Ghz, but what i need to keep in mind is what sort of temps and volts do you guys advise not to go over, i am aware that the standard volts for this CPU is 1.55, which i do not really look to exceed, well not really more then 1.6 anyway ( dont really want to shorten the life of the CPU),
Also i would like to know what are the safe temps for overclocking (Basically what not to exceed i.e. 50c), or what ever they maybe.... just looking for some advice because when i reach a stable over clock (hopefully 2.6) i do not want to be pushing my cpu that much with regards to volts and temps (I wont the cpu to run comfortably)...
I will be using the xp90 heat sink which should be good enough...
i would just like some advice.
Thanks
Thanks
