- Aug 25, 2001
- 56,587
- 10,227
- 126
If you replace one CPU with another, and use the same cooling solution, and the temp as measured by CoreTemp goes down, does that necessarily mean that the overall power draw went down as well? I believe so, personally, but I wanted to get comments on my theory.
The interesting thing is, my E2140 @ 2.8, 1.425v BIOS, got up to 86C in CoreTemp on both cores during the summer, running SeventeenorBust.
I replaced it just recently with a Q9300 @ 3.0, 1.225v BIOS (stock voltage), and under full load (F@H SMP+GPU), it gets up to 71C max so far.
So from the temps alone, can I conclude that my slightly overclocked C2Q 45nm draws LESS power than my heavily overclocked and overvolted C2D 65nm chip?
What's even more interesting, is that the E2140 is a 65W TDP, while the Q9300 is a 95W TDP.
http://ark.intel.com/Product.aspx?id=29738
http://ark.intel.com/Product.aspx?id=33922
