Hello,
Does anyone knows the meaning of:
BIOS Health Setup:
1) CPU Core Temp
2) PWN AREA <------- ??
3) Chipset Temp
How they they compare with MBM 1,2 and 3 (which is which?).
Where is the 2nd CPU temp displayed. MBM 1 = case, and equates to teh same temperature AMD Cool'n'Quiet Dashboard shows at 33C.
Anyone knows a utility that shows the correct temperatures, identifying exacty what thet are, etc.?? I am confuled now!
The temp I get using ZALMAN copper super cooler (& 3 case fans) is between 38 and 44 degrees Celsiuis. With load it goes upto 55C. Too hot??
Same case with OPTY 165 and ASUS A8Ne shows temp in the low 30. Wondering is DFI shows temp show too high figures.
What temperatures you are getting?? What is max?
Also, just let you know that Cool'nQuiet works now with OPTY 939 using new DFI Ultra-D BIOS dated 11/14. Similar, the new ASUS A8ne BIOS fixed Cool'n'Quiet as well. The DFI 939 Infinity BIOS has not been fixed yet. You need to downloa dthe OPTY AMD CPU driver!
BIOS Health Setup:
1) CPU Core Temp
3) Chipset Temp
