Temperature Sensor w/ LCD Display?
LordPhoenix
1,341
Where can I get Temperature Sensors w/ LCD Display? (Black preferabbly). I'm lost...
And, All I have to do is put a little wire thing in between my CPU and heatsink, right?
It will be inside a Lian Li PC-6077B ATX Mid-Tower Case.
allanon1965
3,427
just make sure its not between the actual chip and heatsink, as that would lead to overheating and quick! i put mine between them off to the side a bit. my case has an lcd panel built in to monitor temps of hd,cpu,and video card, really cool!
Rike
2,614
Link.
This is a little more than you're looking for, but I use one on my rig and I absoultly love it.:thumbsup: :thumbsup:
klah
7,070
Not unless you plan on modifying your heatsink with some machine tools.
Read pages 37-40 of this pdf document for detailed instructions:
http://www.amd.com/us-en/asset...ch_docs/26633_5649.pdf
There is not really a good way to measure the cpu temps on processors with an IHS using any other method since most of the heat is transferred through a small portion in the center of the IHS. The outside edge of the IHS is about 5C cooler but is a safer place to position a sensor.
Here are some cheap models:
http://www.bestbyte.net/Product.cfm?ProductID=1352
http://www.bestbyte.net/Product.cfm?ProductID=1165
