Temperature Questions
rkfrompk
14
I finally set up everything in my first ever rig after getting a new power supply today.
I built a
Pentium D930
1 Gig RAM
Enermax Liberty 400W PSU
Geforce 7900 PCI-E
1 40 GIG HD
1 160 GIG HD
and some other crap
what im really worried about though is the temperature. My case has temperature sensors so i can see what the temps of the HDs, CPU, and VGA are. Heres what it says
VGA: 46.7 Celcius (sensor is right behind VGA card close to the back)
HD: 45.5 Celcius (sensor is taped to back of HDD)
CPU: 42.2 Celcius (sensor is taped to heatsink)
when the sensor is left in the air in the case the temp is between 35-38 celcius (guessing this is what they call case temperature)
i have 1 cpu fan and another fan next to it on the back grill. then one small case fan on the top and one small case fan on the side. total 4 fans. the air flow is crappy on the case fans cuz the grill is just a bunch of holes but im gonna cut em wide or mod em or something hopefully.
what i need to know is are these temperatures normal?
^^^oh yeah all idle temps
w00t
5,545
those are fine as long as it doesn't get hotter than 60C you should be find.
