Temperature Monitoring Program
CubicZirconia
5,193
Anyone know a quality program that will let me monitor my cpu and system temps from windows? If it happened to include cpu usage statistics and other useful things, it would be a plus. Thanks.
Edit: Motherboard monitor reports my cpu temp to be 127 degrees celsius at idle, which is incorrect. Anyone have that problem?
Junior0579
404
This will do everything you are looking for. There is a trial version, but the registered version gives you additional features that are worth spending $13 on.
hopeless879
900
I use motherboard monitor without a problem, make sure you have all the setting correct on there, right sensor for cpu, system etc. I couldn't imagine what could be 127º C anyways
Mem
21,476
13
<< Motherboard monitor reports my cpu temp to be 127 degrees celsius at idle, which is incorrect. Anyone have that problem? >>
You sure that`s it`s not on fahrenheit rather then celsius? Look in settings section to confirm this.
MBM works fine with the Epox 8KHA+ , my friend & I use it for our 8KHA+ boards.You probably have it setup wrong.
