Temperature Monitoring On Screen Display GPU/CPU
Cygnus X1
812
I like to use Riva tuner to monitor my gpu temps while I game, especially if I?m over clocking. The latest build of Riva tuner does not support monitoring for the 7900gt?. Is there another program that will do the same thing? I.e.: display the temperature on the screen in the corner while I game?
On the same note is there a program that would do the same for my CPU? Customize A little temp number in one of the corners so I can watch the temps. Thanks
fliguy84
916
since you are using Asus mobo, you can use Asus Probe. It has the history section which will monitor you cpu temp
Cygnus X1
812
I do have that running and for the CPU that is true. I can record the history and then check temps for overclocking etc...
What I'm asking is there a program like rivatuner that supports on screen monitoring real time. When Rivatuner starts supporting the 7900gt I will use it, but will not overclock my new card until I can real time monitor the temps. I want to start overclocking:(
If Rivatuner is/was the only program that can do this can someone please speak up so I can rest this issue. Thanks.
