Temperature monitoring and fan settings with NVIDIA?
anyusername
232
I had been using ATI cards but decided to switch to NVIDIA this time. In the ATI Control Panel I was able to set the fan speed I desired and check the card's temperature.
I don't see anything like this in the NVIDIA Control Panel. Is there an extra software made by NVIDIA that has to be installed in order to do this?
I have a GTX 580 btw.
aigomorla
21,065
3,570
u need MSI Afterburner... or a software which supports the card and the fan's PWM function.
Dribble
2,076
611
another vote for MSI afterburner, great software.
+1 you can see/tweak clocks, voltages, fan speeds, and have several different set-ups you can switch between on a key press. Very easy to use and works very well.
