Temperature monitor for EpoX 8K7A/8KHA
serialb
I have been looking for a temperature monitor for the above mentioned Epox board. I tried installing VIA HM from the motherboard CD it never installs correctly. How do you Epox board owners check your CPU temps? Thanks.
serialb
This little nifty Epox tool called USDM... I absolutely love it. It doesn't suck up as many resources as Motherboard Monitor (even though thats a way more powerful program) especially since I only need temps and voltage i/o readings.
Yvo
I tried that USDM utility from the installation disk. However, it never installs right on Windows XP. I tried USDM107LM.exe and USDMSetup.exe together and/or alone but it still doesn't load up correctly. Any better instruction out here besides that readme.txt?? Thanks.
serialb
MBProbe is a program which monitors voltages, temperatures and fan speeds and works great with the 8KHA+. Be sure to read the instructions on needing "giveio.sys" for NT based systems. I changed a setting in MBProbe so that it reads voltages using a divider for the Winbond chip and it looks better with the negative voltages.
Voltage]
Vccp1 = 1.74
+5VSB = 4.95
+3.3V = 1.52 [AGP4x]
+5V = 4.87
+12V = 12.10
-5V = -4.07
-12V = -11.63
Vbat = 3.07
[Temperature/C]
Motherboard = 25.0
CPU = 43.5
[Fan Speed/RPM]
CPU = 5035
Chassis = 4090
