I have just upgraded my old i7 920 to a 5820K, and running some tests. The old CPU had a maximum temperature difference of 5c between cores, while i'm getting the following results when running OCCT test on the new CPU (min and max temps):
Core0 26c 61c
Core1 22c 59c
Core2 23c 67c
Core3 24c 62c
Core4 23c 63c
Core5 26c 61c
Notice core2 running 8C hotter than Core1 under load. Is this a good/acceptable difference, or should I bother to reseat the cooler (it's a bit of a pain in the... trying to match the screws while holding it still, without smearing the thermal paste all over the place).
I don't know wether or not this is a good result or not. Certainly a bit worse than the old CPU, but there are two more cores as well. I think the temps are pretty good otherwise (though i'm running it with large data packets and only 10 mins so far), considering it's running at 4,4Ghz with 1,9V Vcore.
Core0 26c 61c
Core1 22c 59c
Core2 23c 67c
Core3 24c 62c
Core4 23c 63c
Core5 26c 61c
