Temp Sensors Help
Splice33
7
Kinda stupid really, but I dropped a screw on my K8N SLI Planinum, and right away MBM reported my temps as case:cpu -38 : -48 it doesn't change either. I went into the bios to check what was under health settings and the screen froze.
Am I screwed? (lol pun wasn't intended till I saw it)
btw. the screw landed just beside the power connector.
Thanks.
K8N SLI Plat, A64 3000+, 1024MB RAM, Geforce 6600.
PurdueRy
13,837
4
were you working in your computer with the power running? Shame on you! Others appear to be having the same problem though if you go over to MSI's forums
Roger
22
I had the same problem, without the screw though. I'll have to check other diagnostics.
