Temp ratios,ambiant,case,cpu????
Ringer
120
Just wondering what all your temps are. Curious about temp ratios. How much of a diff your room to case temps are and case to cpu temps.
this is my server under normal load:
Ambient temp(room temp) =21c
Case temp =23c
CPU temp =38c
Hardware:
AMD 1200@1400
512 ram cas2
Iwill kk266-r
2x IBM 7200 striped
geforce3
SuperPickle
1,256
Right now, under Seti load:
ambient: 19
Case: 21
CPU: 35
Bird 1.33@1.54
512 Crucial PC2100 ECC registered
Abit KG7-RAID
10K Ultrastar U160 18.6G
WD 30 7200rpm
Radeon 64DDR
Ringer
120
so our ratio would be comparable,albeit yours is very efficient.....2 degrees diff between case and ambiant and about 15 degrees diff between cpu and case. What type of cooling are you using? ie., sink and fan, how many case fans and if case is modded or not. Thanx...
SuperPickle
1,256
Well, I'm kind of cheating because I just got my water-cooling setup running tonight. Previously my temps were as follows:
Ambient: 19
Case: 21
CPU: 40
I was only running 1.33@1.47 at the time with an SK6 w/Sunon 80mm 38cfm fan. My case is a modded full-tower with 4x120mm Panaflo H1A's all running@7v. 2 side blowing on the mobo and 2 top exhausts.
beatle
5,661
I have a 1.1 tbird @ 1.33, 1.85v, 2 intake panaflo L1a, 1 exhaust, 1 PS.
Ambient: 23
Case: 23
Chipset: 30
CPU: 44 (idle)
