Temp questions at 4.4ghz with Prime95... updated with pict of copper tip of HSF
Jman13
811
24 hours of IBT is just not necessary unless you just like making your chip hot.
Lyfer
5,842
I think 4.2ghz @ 1.23-.24v is my sweet spot, maybe later this weekend if I have more time I'll try 4.4ghz at the same voltage. I've ran prime for 3 hours straight at it was from 57c-69c. Will install apps and make sure everything else is in working order (i.e. sound/sleep mode/etc).
Jman13
811
Same here. 4.2GHz at 1.23V...tested with prime95 overnight. Above that I need a lot more voltage (though still well within limits at 4.5GHz, but I need 1.34V.) I'd rather have the much cooler chip and sacrifice 200-300MHz, at least for the time being. In a year or so I'll probably get a better cooler and push it as far as it will go.
PhoenixEnigma
229
Intel burn test was designed to do just that, burn up your processor. I do not run it for that reason. Anyway running OCCT Linpack my max temps are 58-63-62-61 with a 4.2 overclock and 1.24 v. Running prime95 my max temps are 53-54-55-55. Hope this helps. Edited to add hyper 212 evo.
You're aware IBT is also just a frontend for Linpack, right? It's the same code as OCCT, just with a different front end.
