Um... I assume there's only one probe... so the program or the BIOS must be buggy, right? Try updating the BIOS, maybe use a different temp monitor app... see whose result doesn't get confirmed. JM2C.
It'd be a good idea to get the latest BIOS release as hjo3 mentioned. I know that when I received my Abit NF7-S 2.0, my BIOS reported excessively low temps. Updating it corrected the problem and reported the correct readings.
