Temp monitoring progie
cfrage
53
I cant't seem to find anything that'll work with my 9npa. I've tryed Epox's USDM beta, nvTune, SPeedfan, Motherboard Monitor... nothing seems to work. Anything out there?
RobbyG
86
The USDM utility that came on the Epox CD works fine for me as well as Speedfan and Ntune (I'm using the 6.53 Nvidia drivers). I think someone mentioned that the USDM from the website does not work correctly.
If you have a newer bios that supports Epox ThunderProbe you can download that from the Epox International site here.
cfrage
53
I'll check out ThunderProbe. I couldn't get either version of USDM to work. I'm using the second to newest BIOS. For some reason the newest bios wouldn't take changes to alot of settings.
RobbyG
86
I'm using the 03/22/05 Bios and my system is rock-solid. If you don't need X2 support you may want to give this one a try as it was the last one before X2 support was added and the USDM from the CD should definitely work (although I don't think ThunderProbe will work with this version). Check out the big thread on this board since others have reported various issues with the newer Bios versions.
