Tell me why I don't want an S600!
Ferzerp
6,438
107
I want to complain about the suspension cost, but I know my car is just as bad if I have to replace a shock.
rommelrommel
4,408
3,177
If you could find an old fart driven mercedes maintained one I'd be tempted... hell I've been thinking about it for a toy. They are SOOO cheap for what you get. A lot of the forums suggest that you're better off to spend the extra coin for a S65 if you intend on hooning the car. Also, having the coil packs done recently is a big positive, they were revised and the new ones are less prone to dying.
You just have to budget for some major repairs at some point... eventually you're going to lose a coil pack or have a ABC problem and it's going to cost several thousand dollars to fix.
jlee
48,517
223
Yeah, it looks like it'd run about $2500 to replace all four corners re: suspension. Lifetime warranty, though, so at least it'd only be once.
JulesMaximus
74,528
908
Who do you think buys a $100k Mercedes? :D
rommelrommel
4,408
3,177
First owners who trade em in every 3-5 years :p
Unfortunately after that it's pretty mixed. You end up with a lot of owners that thought they would buy a 150k car for 40k rather than a new ES350 and let the maintainence pile up when they find out how damn expensive it is.
jlee
48,517
223
Yeah, I checked a few carfax's on Autotrader and they had 4-5 owners. Kinda scary over 10-12 years.
AznAnarchy99
14,695
117
My mom has the same generation S430. TBH it is a nice car but you can definitely see its age. She had some issues with the shocks/hydraulics, oil leakage, etc and it has cost her a few thousand dollars each time. The car is at about 200,000 miles now so its about time to give it up (well I'm trying to get her to give it up but she doesn't have payments on it so shes meh)
Jimzz
4,399
190
That's because it only take a year or 2 before they realize their horrible mistake. ;)
My wife HAD to have a German luxury car. Found a E350 Mercedes with a pile of options, no leather though I mean it was only a 60k car, in great shape and clean record. After 1 year she sold it. I warned her but she had to have it and learned the hard way.
Insomniator
6,294
171
I'd imagine you'd have be some wizard to properly main a gigantic v12 benz, loaded with technology from 10 years ago. Plus they are all automatics :(
Would sound nice I'm sure though!
rommelrommel
4,408
3,177
The only spell you need is one that gives a healthy supply of hundred dollar bills.
A decent mechanic with STARscan or whatever it is can do it, even the labour isn't too terrible on most of the common problems... it's the parts. My GF and her mom both have 2009 diesel ML's... both are low mile and not driven too much, but they are good for 300-500 a month in repairs on average.
JulesMaximus
74,528
908
http://carbuying.jalopnik.com/the-180-mph-cheaper-sleeper-the-story-of-my-mercedes-s-1534030903
Example
I bought my '04 CTS-V and drove it for two years, and then sold it for a little more than I paid. If I can find another screaming deal, I'm tempted to try an S600. I'm not afraid to do any work required on it, but I'm not sure how much might fail that requires proprietary dealer-only computer stuff to diagnose/repair, or how often expensive stuff fails.
Anybody here have experience with one?
Nice car. Not crazy about the chrome wheels though. Would look nice with some later model AMG wheels.
Like these.
attachment.php
drbrock
1,333
8
I looked into buying a CL600 a while back. Insane maintenance costs. If the things did not break down every two seconds I would def be buying one. It could be a great weekend car. If you put any mileage on these you will get eaten alive. 30k for a second car is not in the cards for me though.
BUTCH1
20,433
1,769
Sure.
http://mbworld.org/forums/s-class-w220/132373-s600-renntech-dyno-ed-742rwtq.html
Lots of people are doing it. Some stuff is a lot stronger than you'd think - stock MR2 Turbo transmissions can take over 800whp. Stock is ~170.
So it is doable but like I said, pray the rest of the drive-line is over-engineered or you could wind up with a 700HP car needing a $6K tranny, maybe if you drove it somewhat sanely and avoided burnout's that Bruce Springsteen writes songs about you might be OK.. :D
jlee
48,517
223
Burnouts are less load on the transmission than actually getting grip. :p
Anyway, this won't happen for a while. New project. :D
rommelrommel
4,408
3,177
There are guys pushing more HP (they usually build AMG 65's tho which may have stouter parts in places) and driveline hasn't been an issue. They seem to be quite over engineered in that respect.
Fenixgoon
32,048
10,822
A lot, but initial cost of entry is double or more. At the rate prices are decreasing, I'll probably be looking for an 09+V mid-late 2015, but we'll see.
Kinda tempted to try an S600 for a couple years before a V, but I'm concerned about the Mercedes maintenance.
why not wait it out then? another year and you get a massive upgrade with far less chance of maintenance headaches
rommelrommel
4,408
3,177
Because owning a v12 merc is pretty damn cool.
Also the merc probably has more potential, they can push huge power without cracking the engine open.
jlee
48,517
223
So, I still want one. :(
Research says the drivetrain is pretty damn solid, with the exception of the coil packs (2x $850). The biggest headache is the Active Body Control suspension...while apparently quite incredible, it likes to leak. If you maintain it well, flush the fluid regularly, etc, it's supposed to be decent. BUT...how many people flush their suspension fluid every 20k miles? I'm guessing not many.
They're so cheap!
Fenixgoon
32,048
10,822
it's ok. i still want an S8 V10 <3 :D
if you can do all the maintenance yourself (and it seems like you're the handy type given how much you do on your MR2), then it might be worth getting a veritable spaceship. otherwise, i'd probably pass.
JulesMaximus
74,528
908
How much would he drive it is the question. A few thousand miles a year and it will probably be pretty good if it has been well maintained.
I would try to find one with relatively low mileage and complete maintenance history and only keep it for a few years. Be prepared for some hefty maintenance bills though if anything goes wrong.
