HELP!!!
I got a Tekram DC-390U3W sitting here. The manual is wrong! It shows only 2 jumpers for setting the PC64/32 bit....but there are 3 jumpers. By default it's set:
JP2 - ON
JP1- 1-2 ON (it has 3 pins 1-2-3)
JP3 - OFF (no documentation in manuals or on-line)
I'm putting this into a 32-bit PCI. How do I set it?
The manual is also confusing about the cable. Should my drive to on the END or in the MIDDLE? They included an active terminator so I do know that will go wherever the hdd doesn't, duh. Also, does anyone know if this IBM has "internal termination"...the manual says that LVD devices have internal termination disabled by default and you cannot change it.
arggggg...the PAIN!
JP2 - ON
arggggg...the PAIN!
