With a 2500 , the cpu physics tests will elevate the overall scores VS a i5 750, but even in Performance settings, the graphics test is pretty much gpu bound.
Here are some 3dMark11 scores for comparison, benched on an older i7@3.6, which would be essentially identical to an i5-2400: http://www.neoseeker.com/Articles/Hardware/Reviews/Sapphire_HD_6850_VaporX/6.html
Shows the 6850 at about 200 above the 7770, but assuming the latter is getting excellent tess scores, the performance in older games will be way below the 6850, and the performance in tess-based games should be higher.
Graphics Score 3015
Physics Score 12379
Combined Score 3018
Graphics Test1 14.69 FPS
Graphics Test2 14.86 FPS
Graphics Test3 17.93 FPS
Graphics Test4 8.77 FPS
Physics Test 39.3 FPS
Combined Test 14.04 FPS
This is the perfect mobile chip. And for that the retail desktop users have to pay, because otherwise the capacity goes to HP or Dell
In one year time this card will sell for sub 100usd and still make a healty profit. 128bit bus, and aprox 130mm2!, this can be made very cheap when 28nm prices goes down, and NV brings some competition.
You want cheaper and better performance and dont have to care about thermals and power,- choose 6850.
Clearly the sub 60watt part, 7750 will be priced out of this world, because it will have absolutely no competition in its niche market.
Hopefully AMD will price those cards at the highest possible.
It really should be a $150 part even for the full chip. Cape Verde is only 10% larger than Turks, and you can find a 1GB GDDR3 6670 for $85 even without a rebate. Power consumption should be similar, so board costs will be about the same as well. Even with the more expensive process, the total cost of a card might only be 10% or so more than a HD6670, with costs getting closer to the 6670 as the process matures.
Given the volume that these cards will see, if AMD doesn't have competition in this space for awhile they should profit handsomely if they can sell them at $150. I hope GK108 is launched in a reasonable timeframe and both of them help push these cards down to $100 where they belong.
I really do not see how this card will ever match a 6850. 640 Streaming Processors? 16 ROPs? 128-Bit Memory Interface?
All of these are significantly worse than 6850.
The stream processors are different to those in the HD6850.
The ROPs could be more efficient.
The memory can't be helped that much except by optimising the GPU to make less memory calls with even better Z-culling etc.
But from the outside it does looks like it will struggle against an HD6850 based on the specs, not that it actually matters.
Performance isn't the important thing. Price/performance is what matters, so hopefully the headline figure is off the mark and it's not a "sub $200" GPU (implying $150~$200), and is a "sub $150" GPU so that price/performance is good, even if absolute performance isn't the best.
If it's slower but cheaper, that's fine.
If it's slower but more expensive, that's a problem.
http://geizhals.at/eu/735500Chiptakt: 1000MHz, Speichertakt: 1250MHz • Chip: Cape Verde XT • Speicherinterface: 128-bit • Stream-Prozessoren: 640 • Textureinheiten: 16 • Fertigung: 28nm • Maximaler Verbrauch: keine Angabe (Betrieb), keine Angabe (Leerlauf) • DirectX: 11.1 • Shader Modell: 5 • Bauweise: keine Angabe • Abmessungen: keine Angabe • Schnittstelle: PCIe 3.0 • Besonderheiten: AMD Eyefinity, integrierter 7.1 HD Audiocontroller, unterstützt CrossFireX
