BrightCandle
- Mar 15, 2007
- 4,762
- 0
- 76
There are like 6 different manufacturers releasing Gsync monitors this quarter and the next, some of those companies are releasing multiple monitors, so we are looking at quite a lot of available models. The only one you can buy today is the Asus VG248QE.
What I still don't get about Freesync is how often the refresh rate can be changed. Gsync literally makes the GPU the source of the refresh moments but it sounds like Freesync is quite different and can't change the frequency of the monitor continuously. Anyone know what the maximum update rate is exactly? How often can the GPU tell the monitor what refresh it should run at?
