StrangerGuy
- May 9, 2004
- 8,443
- 124
- 106
I don't know about you guys but if one wants to spend ~$200+ on mobos alone I think they are crazy not to go straight up to 5820K + X99.
Then the "rest of us" means those that have the attention span for a 3 minute video and can do simple math, which I've broken down in this graphic. Clearly each game is 20%+ faster:Again, it was 3 games, and the one in "dominated" was older game. As for the "rest of us" does not make the majority.
Really? Did you not watch the videos either? Those are clearly identical scenes picked to make it as clear as possible to even the most basic reader the improvement of a new hex core. It's so far beyond proving the superiority even at identical clock speeds everything else is moot. I could have done something like this:Not fair to take the 1 sec where the fps difference the most and proclaim 20%+ faster, take fps difference over time and add min average and max to do it properly?
Yeah tell me about it! Some of those boards for quad core CPUs are like 300 bucks. That's so ridiculous to spend that much on a board for a quad. That's like putting Lamborghini tires on a pinto, or something like that.
I'll admit those are nice gains although these games are a best case scenario and I would like to see a more reputable site do the same tests to see if the differences are that large. I'm skeptical of these results. Why the huge RAM difference? And if you look at the CPU utilization of the 4790K compared to the 5830 feeding the GPU's it shouldn't translate into 20 percent difference. Need to find the real bottleneck here, if it turns out to be the extra cores than I'll eat crow 😅
No doubt 6 cores will last longer than 4 but I'm thinking the PCIe bandwidth has something to do with these gains more than the extra cores. If it's a PCI bandwidth issue the cost difference skyrockets when comparing cost of CPU, Motherboard and RAM.
Also curious if Radeon Fury's show similar results or if 980Ti's are simply harder on the PCIe bandwidth.
Would be nice to compare with Windows 10 as well since that's RTM'd now.
Yeah, it's freaking hilarious that the Linustechips/Reddit know-it-all fools are still spouting the "unlocked i5 is still the PC gaming master race" meme. This crowd LOVES to scream how X99 is a TON more expensive when it really isn't in reality.
DDR4 pricing is already at parity with DDR3.
A "entry-level" ~$200 Asrock X99 Extreme blows the doors off any S1150 mobo priced similar or below in features.
Then lastly a 5820K is only a *mere* $140 more over the 4690K. Factor in longevity and resale value down the road and its a no-brainer.
The only time S1150 CPUs make sense if you are sticking to sub $100 mobos and you shouldn't even bother OCing on S1150 when the 4790K exists.
DDR4 performance advantage over DDR3 in gaming is neglible. If someone has DDR3 RAM, that is an extra (and sunken) cost.
You add 100 dollars extra for mobo. You add 140 dollars extra for CPU. You're already looking at 320-360 dollars extra for the upgrade. That is a new GPU for a lot of people.
And since the vast majority of people are on a single dGPU, can you make the claim that X99 is worth it? We're looking at a high-end SLI config here, which is a far cry from the average gamer. Would you see a 20% increase in performance with a single 970? Very unlikely.
Actually, the unlocked i5 is a far better choice for the vast majority of gamers and if you can't see that, the joke's on you.
but I'm trying to educate some of you. However, clearly it's in vain since your fragile egos can't handle stating the phrase "nevermind, on second review, you're right," so continue to be ignorant, not worth my time.
L2read last paragraphs, bro?
Who runs at those clockspeeds anyway. I only have a single GPU at 1200p and run my 5930K at max turbo all cores 3.7GHz. I couldn't even get 4.0GHz @ 1.2v. [Poor quality] chip maybe but even then you are pushing Haswell beyond the limit at 4.7GHz.
it's still a considerable price difference between a six core X99 and a four core 1150.
the reason most people go for the 4790k is that they can afford it. most people who have normal jobs and like PC gaming simply cannot excuse the extra cost.
here in the UK, (and most of europe), a 5930k is £400 instead of £230 for the 4790k.
the mobo is £150 instead of £50.
regarding the fact that they might own top tier GPUs, it's because they are, well, uneducated. and in these last 6-7 years there's been a big cultural buzz around GPUs, and more and more people spend a lot of money on it, because they are led to believe that the GPU is what gives you the most gaming oomph.
which .. is actually true. in most games.
if you are shooting for max performance on 1080, maybe even triple 1080, your budget is still better invested in the video card rather than the processor; witcher, GTA, are unusual products.
I do.
4.7 at 2.1Vin 1.35vcore is completely feasible and quite cool (54C) with a good custom loop.
They must have found the 3 games this occurs on. I have a 4.6ghz 3770K pushing 2 1450mhz 980 Ti's, and every game I've thrown at it stays above 90 fps
