Tech questions on Opterons
The Internal
Greetings,
Okay, so correct me if I'm wrong here. Opterons use socket 940. They obviously use registered (aka ECC) RAM. In a multiproc setup, do they each require their own RAM? Can you run dual Athlon FX53s on socket 940? Which has the best overall price/performance ration: single Athlon FX-55, dual Opterons, or quad Opterons? Do Opterons suck ass for gaming, or are they just a little slower than the standard Athlon 64s? What should someone expect to spend on just the motherboard, procs and RAM for a dual or quad setup?
Thanks
K, more questions. This Tyan Mobo has two PCI Express slots, but obviously not SLI. Is a dual Opteron mobo basically just two in one? Can you use just one graphics card for the whole thing? Does 3ds Max have support for dual Opteron and dual graphics cards? Do these motherboards require obscenely expensive cases? Is transitioning from high end consumer level system building to Opterons a huge pain?
The HIGHLY TECHNICAL forum is not for purchasing advice. Please post in the correct category.
AnandTech Moderator
The Internal
Well, I don't seem to be getting any responses... does anyone at least know of any reputable sources doing dual opteron vs. Athlon FX performance benchmarks?
Jul 5, 2004
56
Yes.
This depends on the motherboard manufacturer's implimentation. Non Uniform Memory Architecture (NUMA) gives each CPU its own set of memory, and each needs at least one physical stick. There are some motherboards which use UMA, and the CPUs share the memory.
No, the FX is not SMP enabled.
For your gaming and 3DSMax a single CPU would more than suffice. I have yet to see a quad opteron ATX motherboard.
An opteron would actually be a bit better than an equally clocked A64 because all opterons have the full 1MB cache and dual channel memory.
www.newegg.com find out for yourself.
3DSMax should support SMP, as for SLI, it should be done in hardware when you're working, but I don't know what effect it would have on rendering, I estimate none.
It isn't two motherboards in one. It's one motherboard with two CPUs, the rest operates just like any other motherboard. So yes you only need one video card.
No, but preferably a large case, with a very nice power supply. Some dual CPU motherboards can fit happily in an ATX mid-tower.
Machupo
1,536
www.overclockers-network.com
i've got a Tyan S2882 w/ a pair of 248's and 8 sticks of corsair... it's a dream
first off, it's more like two motherboard that you'd imagine... google "NUMA" (non-uniform memory access) and that'll get you off on a start
