Teamspeak broadcasts my computer audio output...
Anyone know how to set up teamspeak to where it will send ONLY my voice, not the game output? I'm running the sound blaster audigy 2 ZS platinum pro and Windows XP MCE 2005.
Any help appreciated
Uh. I think it broadcasts anything it picks up from the mike, so if you're shooting or whatever and PTT, you're voice and the game sounds will carry.
no this is a common problem with some sound blasters.
I forget how I fixed it... it should be in the faq
play with the windows volume control settings. make sure the mic record setting is selected and turned up and the mic playback setting is turned down. make sure that any record "what you hear" setting is muted.
