T'bird 800 problem, got any ideas?
ericboo
1,137
A7V, T'bird 800 at 950, Geforce MX, default jumpers
Was working perfectly for two months, bumped it up to 9.5 * 105 and all is great. I got to add a simple fan on the greenie heatsink, and then I get a long beep and three short beeps. I drop it down a bit and same thing. I finally return it to 8 * 1.03 and it goes in fine. My wife turns the computer on (as usual something happens) and I go to check my email. My video got screwed up and I had to uninstall and reinstall the drivers because it would not do more than 1024 x 768.
Can the penciling degrade after time, or might I be having another problem. I can live with 9.5 * 100, but it has to be overclocked.
TIA
ericboo
1,137
I would assume that even though the L1 bridges are closed, that it should operate as "normal" at 800MHZ even if there is a problem with the penciling.
