TB Santa Cruz Problems? Help!
I installed my TB Santa Cruz into my HTPC and i installed the software. Well now I cannot control the volume anywhere within windows. Not by the Accessories/Entertainment/Volume or by the Control Panel/Sound and Audio Device. It appears that the software that is installed with the drivers has completely taken over my damn sound control! The problem is my Bluetooth keyboard will turn the MS Volume sound up and down. I can turn the sound down all the way on the computer, but the volume does not change at all! I have to manually go into the TB SC software and change the volume! I hate that.
WTF is that about? IS there a set of Drivers Only that I can download that doesn't include the silly software that TB SC takes over? Or am i missing something in the software that allows me to turn it on and off? It doesnt give you the option to not install anything with those drivers from TB. It's annoying cause my keyboard will only play/stop - FF/RW and launch Media player! But I need volume control.
