The car is knocking so bad I don't even want to drive it.
It is a 96' Taurus LX with the 3.0 220HP duratec engine.
It is at 134k, the knocking started shortly after I got my alternator changed out, but after lifting up the hood and listening carefully, the knocking is distinctly and definitely coming from the engine. The oil has been changed and I even added some Supertech oil treatment. The engine has no leaks and was inspected less than 300 miles ago.
Basically, over the last 100 miles the knocking got gradually worse and worse and now is so bad I am sure driving it is causing engine damage...what are my possible causes and what are the next things I should do for process of elimination?
