Taskbar Temp. Monitor
Is there any program to monitor CPU temp and Motherboard temp, that will display the temperature on the taskbard down near the clock?
Thank you,
Justin Straub
This is the program I use to keep the temperature in my taskbar. At download.com there's a program SpeedFan 4.02 it's freeware and detects your temp through hardware and the chipset. Speedfan link should work but if it doesn't you can try looking it up at download.com
I second the MotherBoardMonitor. It is a bit complicated to set up, but it is pretty well documented. The programmer answers questions on the forums at the site also, a big plus for me.
