14,084
I noticed when I make a tar archive, it includes the full path, ex, if I tar the files in /usr/include/folder to folder.tar.gz, when I untar that file, it actually contains a folder called usr, then includes, then folder, then finally my files. How do I make it so the files are at the root of the tar archive?
Colt45
19,720
cd to /usr/include first?
or..
tar -vcf <outputfile.tar> -C /usr/include/ <folder>
the -C makes tar act if it was in /usr/include/ even if it isnt. The file will still be saved to whatever dir you called tar from (say home, or whatever) [this will make the tar be folder/file1 folder/file2, etc.]
and if you want no folder at all:
tar -cf out.tar -C /usr/include/folder .
note the '.'
I usually just do this though:
cd /usr/include/folder
tar -cf ~/out.tar .
not sure why.
