After for sure. You should eat something (possibly another protein shake?) probably an hour before you workout to give you energy. I usually have a banana and a protein shake an hour before i work out. And a protein shake after as well (on days that I workout).
Originally posted by: Ranger X
I was told that you need to take it afterwards because protein helps to rebuild the muscles that you "tore" during your workout.
