Taking a laptop to Europe and have question about voltage
pjyelton
30
I'm going to be traveling through a number of countries in Europe this summer from America and I'm a little paranoid that I might screw up my laptop. I've heard that some laptops have no problems but others can get screwed up royally and I have no idea of how to find out if mine could handle 220 VAC that I think some countries use.
My laptop is an HP Pavilion zt3000
matt20
13
I would ask HP.
Some laptops can automaticaly switch betwen USA and Europien voltage. Ask for yours.
Regards
vegetation
4,270
Before you do anything, look on the power supply itself. There is always a little label that shows the input and output specs. Look for the input AC number. If it gives a range like 100-240V, then yours will work.
Nickel020
753
It depends entirely on the PSU. There should be a lable on it stating the voltages it works with. If not, just ask HP, they should know. The label should say "Input:100-240V" and somewhere the frequency should be noted: it has to work with 50-60Hz.
lilmoonee
almost all A/C adaptor can handle 100-240 voltage at 50-60hz. this is especially for portable devices. in short it should work.
pjyelton
30
Thanks all! I checked the A/C adapter and it looks like it'll work. I feel like such an idiot, I checked everywhere BUT the A/C adapter including calling HP only to sit on hold for an hour and have a lady say "Oh I'm sorry, thats a laptop question, I'll have to transfer and put you to the back of the line. Have a nice day!"
