Kelemvor
Howdy,
At work we have training classes going on all the time. We just have standard rectangular tables that get setup in the rooms. TO get LAN access, they have a bunch of Netgear, 8-port hubs, that they set on the tables and plug into the LAN jacks which are on the floor.
I want to come up with a way that we can basically have LAn jacks built into the tables so the hubs don't have to be sitting on top of the tables and the cables can be underneath, etc.
Preferably I'd like something that is mostly flush with the top of the table.
I know I can just buy a bunch of keystone jacks and stuff like these: http://www.lanshack.com/Keystone-Flush-Wallplate-P17C56.aspx
and then punch down the cables and such. Then I could just mount the hubs underneath the table, hardwire the hub jacks to the backside of the keystone jacks under the table, and then have the cable going back to the LAn jack run down the table leg or something.
I'm just looking for other ideas on how we could accomplish something lke this.
I'd either want to have 2 set of jacks,one at each end, or a line of jacks running down the center of the table. I don't think that makes much difference.
The goal is to do this as cheap as possible.
From LANShack.com, for each table, I'd need a 4-port panel, a 3 port panel, and 7 keystone jacks. That'd come to about $18. We have plenty of cabling and we already have hubs. Since they are 8 port hubs and 1 port has to go back to the LAn, that leaves 7 for use on the table...
Thanks for any other ideas.
