- Mar 12, 2005
- 120
- 0
- 0
My t.v. is broken and i was thinking if i could replace it with a t.v. tuner. I just want to watch t.v. .. not record anything. Can someone recommend me a decent t.v. tuner thats compaitible with windows xp in the $35 range?
Originally posted by: Some1ne
You can do that, although you'll be limited to the display size on your monitor. I think I've read good reviews about this card for $45:
http://www.newegg.com/Product/Product.asp?Item=N82E16815116626
If you want a cheaper one, try this:
http://www.newegg.com/Product/Product.asp?Item=N82E16814122221
I don't know anything about it, but Leadtek is generally considered to be a good brand, and I'm not really familiar with the brands on any of the similarly priced cards.
