I doubt there was little additional air being forced down the middle. It's like the equivalent of putting a 20mm or 30mm fan in the middle.Originally posted by: Elcs
I was very interested in the TMD fan. Even considered modding my Tt Volcano 7+ to accomodate one but that never happened
I think YS Tech ran into some major stability problems and burning out problems as they tried to increase beyond 70mm. The concept was quite a good one and the extra air hitting the centre of a heatsink would probably have been favourable but it didnt take off.
As Howard said, I think one of their main problems was that they burned out and hence unreliable.
I've used two Vantec AeroFlow TMD HSF's over the past two years. Both are quieter than equivalent units with regular 70 mm fans on them, and both do an excellent job of cooling.Originally posted by: bR
I have 3 that have no problems at all. Hell I even took one apart and bent the wires connecting all points together... oops. They had problems of burning out when its screwed a little too tight and something was shorting inside.
There is a web site named Frosty Tech (or something similar) at which the techs regularly test cpu heat sinks against standards they created to test against. The AeroFlow tested well there, doing a decent job of cooling, and posting an equally reasonable showing on noise.
:thumbsup:
