T-bred heat question
AA0
1,422
Are there any firm number on the T-bred heat situation? I know AMD releases spec for the max of the XP, and Tbird, but I'm not sure if the T-bred is out yet. I'm writing an article, and would like to include the data for those CPUs.
I may end up trying to calculate the new CPU wattage, and using that.
Mikewarrior2
7,132
No firm idea, however, both cnet and other websites have posted 1.65V as the new Vcore, which owuld make the tbred awfully hot.
Toms has posted 1.5V as the default voltage. Time will really tell.
However, even at 1.5V, you're looking at a chip with a high Wattage/Sq MM number.
Mike
