I have a rather old system, but I'm trying to milk as much performance out of it as I can. My comp contains the following:
Athlon T-bird 1.33
MSI KT3 Ultra (KT 333 based, AMI BIOS v. 5.x)
PC 2100 CAS 2.0 (256x2), Kingston PC 2700 CAS 2.5 512 MB
Geforce 3
etc.
The problem is that I can't seem to keep synchronous memory timings at anything other than 133 Mhz. I can change the fsb easily enough, but I can't seem to get the RAM frequency to change with it. The options for RAM frequency configuration are: SPD and Host Clock. I have it set to Host Clock, which should make it run at the same speed as the fsb, right?. However, no matter what I do (I have tried all the settings) it won't change the RAM frequency.
I've raised the RAM timings to the highest available and that didn't help. I know that half the RAM is only rated to run at 133, but the problem isn't stability. The RAM literally won't change frequency, higher or lower.
I know this is kind of an old board, but if any of you have ideas, I'd really appreciate it.
Thanks.
Athlon T-bird 1.33
Geforce 3
etc.
Thanks.
