T-Bird Cooling help needed
FCBL
23
I?m running a G7DX board with a 1.2 T-bird.
The bundled software that came with the board to check the temp of the CPU is running (displaying) almost 30c hotter than the bios temp?
Is there good software for checking the CPU temp from within Win2K?
enginjon
659
Motherboard Monitor seems to be a trusted program for many. You can download all over the place. I think both versions 4.xx and 5.xx work with Win 2k
