T-bird cooler rated at 1.2G for $11.30
nomind
37
This may not be a hot deal but it is excellent for those people who DO NOT want to spend half of Duron price for a CPU cooler. Taisol CEK733092 CPU cooler is a cheap and reliable solution for moderate overclocking. It is quiet and efficient. (my 2 c's).
The cooler reduces my Duron temp at least 4C compared with AMD stock fan (hard to measure becoz of room temp changes). My Duron is overclocked to 1050 Mhz from 600 Mhz. The CPU temp. is around 41C when loaded.
Taisol LINK
dcdomain
5,158
Isn't the stock hs for AMD chips a Taisol too? Does anyone know which model number? I forget...
dawheat
3,132
93
Price isn't too bad, but shipping is around $7-8 for standard ground. Still an ok deal but shipping is a bit high.
nomind
37
Now I recalled that AMD uses Taisol fan but I don't know which model was used. My duron 600 cooler has smaller heatsink and uses 50mm Delta fan and this Taisol cooler use 60mm Delta fan. The stock fan is rated 9 cfm (?) and the 60mm fan is rated 18 or 21 cfm (?).
Losty
1,136
for the 850's and higher i think it's the taisol 734
the 734's for worth it....if you can find it for 15...
the cgk are like the 734 but it's forged...cost me around 24 at inflowdirect...
nice and quiet fan...
TatSteeL
247
the most important for cpu fan for me is db smallest possible. I once bough a suck ass cpu fan and its loud as hell, it makes my cases rumble.
Vpham97
477
There was a group buy on this item on Anandtech.
Together we bought approximately 200 of these little sucker and price them at ~$13 shipped!
