Here's the specs on the system
Generic Mid Tower ATX case
AMD Thunderbird 800 mhz (Not overclocked)
20 GIG 7200 RPM Maxtor
Geforce2mx
Asus A7V
Alpha Pal 6035
Sunon 80 MM. 42 CFM
Regular Silicon Grease (Applied a little more than a thin layer.)
PCI Slot Cooler
Ok. With the case closed, The CPU will go up to 130 F, Mobo will be around 100 F
When I take the case off, and aim a regular human Fan at the cpu I can reduce the CPU temp down to about 115-120 F and lower the mobo down to 90F. But I don't want to leave my case open and aim the fan at my PC forever.
I've been reading everywhere that a regular average T-Bird CPU temp should be around 100 Degrees. What is the real average Temps for AMD T-Birds? What am I doing wrong? I have all the "better" cooling devices and my PC isn't even overclocked. I was thinking about adding Artic Silver as my Thermal greese, perhaps that can reduce my temp a bit.
What's your opinion guys?
Geforce2mx
Asus A7V
Alpha Pal 6035
Sunon 80 MM. 42 CFM
PCI Slot Cooler
