T-BIRD 700 and KT7-A Raid **Need advice on Overclocking**
KRidder
38
Hi All! Well, I finally set the thing up... It Rocks! Now to the OC'ing...
Can you give a few suggestions as to the BIOS settings?
Here is the current config:
Case - Antec SX830 (SPECS HERE)
TBird 700 (Unlocked from Factory) with Cooler Master DP5-6H51 (SPECS HERE)
(2) 128MB PC133 Corsair CAS-2
(1) 20GB Maxtor UDMA 100 (IDE Channel 1)
(1) Cendyne 12x DVD (IDE Channel 2)
(1) Zip 250 (IDE Channel 2)
Xentor TNT2 Ultra 32MB - (PCI Slot 3)
Soundblaster Live Value - (PCI Slot 4)
Creative Modem Blaster 56k PCI - (PCI Slot 5)
Windows ME - All updates Installed
Motherboard BIOS version - kt7_wz.b03
VIA 4in1 v4.28
I'm looking forward to seeing how fast I can take it to... Thanks for all you suggestions... The user community is what makes this board the best...
loosbrew
1,336
do a search, there are plenty of posts here about oc'ing your setup. just bring the fsb up to 133 first off. then run some benches. do them a few times to make sure things are stable ie..memory bench, HDD bench etc. then go up from there a few mhz at a time, all the while keeping an eye on your cpu temps.
good luck
loosbrew
