just put this thing together 2 days ago
oem athlon thundrbird 650@780
chrome orb cooler
msi kt7pro2a
2 128mb mushkin pc133 cas2 rev2
ibm deskstar gpx75 7200rpm 15gig
voodoo3 3000
hp 9100cdr
panasonic 12x dvd
inwin midtower 300w powerman p/s
sblive value
2 80mm case fans in/out
win98se
if I try to go with 8x mutiplier.The system will only post then freezes but i dont think its tempature cause it says cpu temp is only like 100f. voltage is turned up to 1.85 max on this board
I would like to be able to get at least 830mhz out of it
any suggestions would be greatly apreciated
It runs perfectly stable at 7.5x and fsb at 104
chrome orb cooler
msi kt7pro2a
voodoo3 3000
hp 9100cdr
panasonic 12x dvd
sblive value
win98se
