System32 folder opens when I start my pc
aic
Why does it open and how do I stop it from opening?
The folder opens up. I am running XP Home SP2.
Thanks.
Thanks for the replies but if you have time I will need some help in doing this. if you have time. How did this all happen?
Are you virus and spyware free? Last machine I cleaned had that exact same problem, and it would only regenerate itself after I removed it from the startup list.
Get SpyBot Search and Destroy (which you should have anyway) and install it. If you go to advanced mode and look under tools, you'll find startup section where you can delete whatever startup entries you want.
However, the problem is more of why this started happening. Windows doesn't just do stuff like that on it's own. 😉
