Hi,
I am building a second computer for the kids from spare parts I have lying around from my previous upgrade. I bought a brand new Corsair PSU (HX620) and am worried that it may somehow be incompatible with my old mobo.
The system :
Asus P5N-E SLI (not running it in SLI)
Corsair HX620 PSU
4 GB RAM
Intel Core2Duo 6420
80 GB SSD
eVGA 8800 GTS 320 MB
I installed the new PSU, and connected the 24-pin connector and the 12v ATX (4-pin). I have tested the 12v to be sure it is working by disconnecting it and trying to boot. They system comes on for 1 second, and then powers off. When I connect the 12v ATX, the system appears to come fully on, the green light on the mobo is on, and all fans are operational. However, there is no beep, nothing comes up on the monitor.
I have disconnected everything but the mobo (pulled graphics card, disconnected SSD and DVD drives), and still nothing. All fans start up including the CPU fan, the green light on the mobo comes on, it looks like it is working, but again, no POST.
So I started over. Pulled everything out, and this time ensured that the standoffs were only connected to the 6 screw holes (there were 2 extra standoffs I had left in just to provide additional support). I remember reading that metal standoffs can cause a short and prevent a POST. Still no dice. I have 2 8800's from my old system which I used to run in SLI, although I am only planning on using one of them. So I switched them out in case one was bad. Same thing. I made sure the SLI selector was set for single card, and that the 6-pin power cable was connected to the 8800.
Am running out of ideas. One thing I could try (but am reluctant), is to hook up that mobo to my new computer's PSU to make sure it can POST. It is the only other 24-pin PSU that I own. Lastly, this mobo ran for years. I haven't pulled the RAM or the CPU, they are still firmly in place from my last upgrade when I bought a new mobo + CPU + RAM, so they should still all work. The only change is the Corsair PSU.
Thanks,
BM
The system :
Corsair HX620 PSU
4 GB RAM
Intel Core2Duo 6420
80 GB SSD
Thanks,
BM
