system won't boot with cable modem on built in lan card
jazzisjazz
272
abit at7max
athlon 1600
boot drive - ibm 36gb 10k scsi on adaptec u160 card
windows xp w/ sp1 all updates as of @ 9/12/ 2003
system will boot normally if cable modem is not connected to built in lan card
if cable modem is connected xp will will offer choice of
last known good - will cause reboot before logon screen
safe mode - will cause reboot after stopping at a repeatable point in the drivers list
device manager does not indicate a problem with the built-in land card
during some reboots xp tried to repair itself by truncating some files and then it would reboot.
I'm currently using the same cable modem to send this message on another system.
What should be done next??
Thanks in advance. I'll post any details needed.
jazzisjazz
T3C
5,324
Is the other system that it works in also winXP?
_.-TechITguy-._
