System won't boot bootable DOS utilities
TJones2
278
Can't get my new system to boot DOS tools for testing hard drives.
I've tried WD Tools, Seagate Tools and both start booting the give me a blank screen. With Hitachi Tools, it loads up, and start detecting drives then stops with a loud screech from the computer speaker.
Its not the CDs, since I've tried them in my other systems and I've also tried using the same tools with floppies in mine. The memory has been well tested and is okay.
Any ideas?
System:
Gigabyte DS3L
Intel e2180
Maxtor SATA 100gb
XFX 7900GS
Antec SP450w
alzan
3,860
I'll start with the basics since you weren't specific:
1) Is your optical drive first in boot order? If not change it BIOS and reboot with the boot CD in the drive. If your BIOS won't let you specify boot order there may be an F key press that will bring up a boot menu.
2) If you have two optical drives and they are setup Master/Slave the boot CD needs to be in the Master drive. If they're set to Cable Select put the boot CD in whichever one has the lowest drive letter (closest to "A").
alzan
TJones2
278
I've tried both using the boot menu and then actually changing it in the bios. No joy.
alzan
That would be obvious, but its often the obvious that's overlooked. I'll check that one out when my son gets off the computer. Thanks.
Oh, wait a minute, that can't be it. Its the same situation when i'm using a floppy instead of the CD drive.
TJones2
278
Okay, I think I now know what it was. Haven't tried any of the utilities since sending back a questionable WD5000AAKS drive. Now that its out of my computer, Seagate Tools now boots up fine. Haven't tried the others yet, but I'm pretty sure that was it.
