I have built several systems before and the latest one is giving me some problems. The crucial system parts are as follows:
Computer Case: CM Centurion 5 Blue
Processor: AMD64 3000+ Venice
Memory: Corsair 2x512 PC3200
Video Card: eVGA 6800 256mb PCI-E
Hard Drive: WD 80GB
O/S: Microsoft Windows XP Pro SP2
Motherboard: MSI K8N Neo4-F
Monitor: Samsung 710N Black
PSU: Enermax Whisper II 460W
With everything in the system, I tried to power it up... The fans and drives all power up. Then I take a look at the monitor and nothing shows up...
I waited a few mins to see if anything would happen, but no post, text, or images appeared. So, I powered down the system and double checked the connections. After which I decided to remove and reinsert the CPU/HSF. It appeared that the HSF and CPU was cold to the touch. After reinstalling the CPU, I tried to power up the system again but no luck and the HSF was still cold to the touch.
After the CPU reinstallation I decided to remove everything but the key essentails, (CPU, video card and a stick of ram). Still no luck. After that, I decided to remove the motherboard from the case to eliminate any possibilities of a short... still no luck. After which I decided to swap in other components from my other systems. (Ram - Buffalo PC3200, Corsair - PC2700, Vid Card - A very old PCI based one, used another monitor, and also tried to use another PSU which was rated at 300Watts.) But sadly, this was the first system build with a 939 A64, so I could not swap in another cpu.
I also tried to test out the included diagnostic device that MSI included, which was a USB connector that had the 4 LEDs (green/red) as a troubleshooting device. That device did not even power up... no green or red leds ever appeared.
What do you think it is?
Please help!!!
- hito
Hard Drive: WD 80GB
Please help!!!
- hito
