- May 17, 2004
- 38
- 0
- 61
Hi all,
I am looking for some system upgrade advice on a budget, hoping to spend around $300-350 CDN or $230-270 USD or so at most.
The games I play are not particularly demanding graphically, examples include Overwatch, Hearts of Iron 4, Football Manager 2016, and CS:GO. However, I have been playing Battlefield 1 recently and while the performance is actually acceptable to me on this machine with low/medium settings (and the game looks good enough too), I am exploring the possibility of a modest upgrade to help boost performance a bit.
The main things I have been looking at are 1) new GPU (but not sure which one would be best value for money); 2) upgrade to 16 GB RAM; 3) add another SSD drive so all games can be stored on it (current SSD is tapped out with OS install and 1-2 games).
I know I can’t fit this all in on my budget, so advice on prioritization would help too. I am leaning towards upgrading the RAM regardless since it's so cheap right now anyway, see what gains I get from that, and then upgrading the GPU with remaining budget, but would love to hear some advice on this.
Here are my core system specs:
CPU: Intel Core i5 3570K 3.4 GHz
Motherboard: Asus P8Z77-V LX
Memory: Corsair Vengeance 8 GB (2x4 GB) DDR3 1600
Storage: Samsung 120GB SSD and Western Digital 1TB 7200 RPM
Video Card: AMD Radeon HD 7850 or 7870 (100% sure it’s in the 7800 family – is there a way to tell in a CPU-Z report which specific model it is?)
Monitor: BenQ V2400Eco 24” and BenQ E2200HD 22”
Bonus points if you are able to recommend products from this vendor, as would be easiest for me to purchase from: http://www.canadacomputers.com/
Thanks in advance.
Thanks in advance.
