Hello, before i state my problem let me give u a rundown of my system specs.
3.2 p4, 1gb corsair xms, BFG 6800 gt oc, Gigabyte GA-8knxp, windows xp pro
Ill start from the begining
I was actually watching a divx movie when BSplayer performed an illegal op. I then retsrated the movie and then while watching it everything froze for a split second. The computer stayed on but i lost all video signal. The moniter wouldnt display anything.
I automatically figured it was the vid card, but i swapped it out for my brothers video card and it worked for a second but then gave me a blue screen message. I couldnt read it because the computer promptly shut down. After that i would once again get no signal to moniter when i turn my system on. Just to double check i brought my 6800gt and put it into my bros comp...and it worked perfectly in his, so it cant be the vid card.
After that i swapped out my ram for a pair of kingston value ram 512's. I put them in......and bam it works. So i figure its the ram and one or both of my crucial xms's are shot. To test I took out the kingston and put 1 stick of crucial back in....it worked.....i put the other stick in (by itself)...it worked....I put both crucials in...it worked again....This didnt make sense to me but the kingston ram wasmy brothers so i gave it back to him and hoped everything would work out fine...we all know how quirky computers can be......
10 Minutes later i get a blue screen telling me windows must shut down to prevent an error blah blah. I figured ok so the curcial is quirky with my mobo but they do work...ill give these to my bro and ill take the kingston value ram......I put the the crucial ones into my bros comp....and its been running smooth for 2 hours...i put the kingston in mine..and once again. it doesnt work....even with the kingston in there
edit: to clear things up my system actually turns on......just no signal to moniter it seems
guys.....this isnt making sense to me. What should i do?
thanks in advance
thanks in advance
