Originally posted by: mechBgon
Allerious, if you need a replacement CPU fan, post what CPU you have and I'll rummage up a suggestion. Or contact Alienware, it's probably covered under either their warranty or AMD/Intel's as long as you're the original owner.
I've considered getting a new fan, but I'm still not sure whether the fan is the problem at this point. In fact, I'm leaning towards other causes. Nevertheless, I have a 2.6 ghz p4 on socket 478. Basically, the system is booting randomly at the moment. Sometimes it will start, and other times it won't, with no apparent change to it whatsoever. This is what gets me about hardware problems - the components you're dealing with seem to have minds of their own. When the system does boot, it takes me to bios with the following message:
During the last boot-up, your system hung for an improper CPU speed setting. Your system is now working in safe mode. To optimize the system performance and reliability, make sure the CPU speed conforms to the specs. of your CPU.
After that, I can leave bios and the Windows Xp boots up normally. Now, I know from that message that this sounds like an overclocking issue, but that's not the case. My system is slightly overclocked - by the manufacturer - and it's been like that ever since I bought it. I haven't overclocked anything else, or changed hardware recently.
Concerning the CPU fan - when I first boot up the system, it works. Then, it slowly starts going down in RPM (according to the bios monitor - personally I can't see a difference) and finally, it dies out after a few minutes. I have no idea of what might be the cause for this, but so far I've taken it as an indication that the fan itself is not the direct cause of my problem. After all, there are times when the CPU isn't hot at all and the system still refuses to boot.
Currently, I'm considering upgrading to Service Pack 2 to see if it helps out at all. I'm still running SP1 at the moment, but I've heard lately about blue screen issues that people have been having, which resembles my own problems because I've gotten a few BSoDs right before my graphics cut out and my system died on me.
Motherboard:
ASUS P4T533-C
Suggestions appreciated.
