System::String to standard::string ?
Lazy8s
1,503
Ok, so I used
array<String^>^drives = Environment::GetLogicalDrives();
and I'm trying to pass it into my function
deliver(string thisDir)
but simply typing
for(int i=0; i < drives->Length; i++)
drliver(drives);
does not work. Obviously the simple thing to do would be to allow deliver() to take a managed string but on theother side I am doing all kinds of string manipulation so that's an option but only if I can convert from managed to standard string on the other side....
I tried
char* str = (char*)(void*)Marshal::StringToHGlobalAnsi(drives);
but it gives me all kinds of errors. I'm using Microsoft Visual Studio 2005 pro. Any help would be REALLY appreciated. Thanks in advance.
Lazy8s
1,503
That gave me a managed char array, but I can find even less info about how to turn the managed char array into standard chars...
array<Char>^charDrives;
for(int i=0; i<drives->Length; i++){
charDrives=drives->ToCharArray();
deliver(charDrives[0]+":");
Still gives the error: error C2664: 'deliver' : cannot convert parameter 1 from 'System::String ^' to 'std::string'
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
You're right. Bad suggestion, sorry :). Hopefully this isn't another one. Take a look at System.Runtime.InteropServices.Marshall.StringToBSTR or .StringToPtr. I think either of these might get you closer to what you need.
